February 24, 2020, 08:53AM
News: Chess Computers Revolution DVD documentary: www.ismenio.com/chess_dvd.html
  Senator likes to draw?!
   Author  Topic: Senator likes to draw?!  (Read 2373 times)
Re:Senator likes to draw?!
« on: October 18, 2008, 08:51AM »
Thanks for the good advice, but I'm afraid tom doesn't have the courage nor the skills to venture on such an undertaking. I asked my hardware dealer, who happens to be an ex-student of the tech where I used to teach and he didn't object. So I'd better leave it to him. He'll probably do it in a few days.
The computer concerned is the Chess Champion mk 5:
It does play, but the LCD screen is very hard to discern. But I'm not even sure that is caused by the leaking capacitors.
« Reply #1 on: October 17, 2008, 11:05AM »
You are right on with everything you have suggested and have said it better than I.... Now lets see if Tom has the "courage" to venture forth and try to save/preserve his games by replacing the "oozing capacitors ". As I see it he has nothing to lose (based on if nothing is done soon he loses by default) and he has an excellent chance of coming out on top of this. Allow me please to digress ...LOL...  I believe it was FDR who once said "you have nothing to fear but fear itself".
« Reply #2 on: October 17, 2008, 05:34AM »
Great points - variable heat guns are great but a bit more expensive and often come in the gun form instead of a rod shape and I find the gun to be clumsy if you need to get into tight spots.
Solder wicks are also terrific once you have played with them a bit to get used to them.  In using them the best approach is to heat the wick at the same time you are heating both the post and the pad, otherwise they sometimes stick to the pad rather than pull the solder away.  So before you use one to remove something the first time, find some old board to practice on so you can heat everything quickly and efficiently.  Get in and get out quickly is the key to protecting the board and the component.
I was lucky enough to have a motorized vacuum solder sucker built right into the soldering rod I used for work.  I think it works best of all, but of course is much more expensive.
« Last Edit: October 17, 2008, 05:37AM by sderyke2002 » Report to moderator Logged
« Reply #3 on: October 16, 2008, 09:17AM »
Hi Sderyke ..... if I may add to your great post I would suggest using a controlled heat (25 watts or there about) soldering gun and possibly one made by a Co. called ISO TIP that makes portable low heat solder guns w/ several types of exchangeable/removable tips . The only other alternative to soldering/desoldering I would offer....would be the use of a solder wick. This is a braided copper solder absorbent medium thats placed over the solder joint you wish to remove and its directly heated.. It's easy and leaves an area now clean and ready to be resoldered.
Hondo
« Reply #4 on: October 16, 2008, 08:49AM »
Quote from: Overtom on October 15, 2008, 12:29PM
... but being non-technical I tend to have nightmares about having to get them out and solder new ones in on my own
Tom,
Soldering is not that tough if you are careful and observe one simple rule - Cleanliness!!!
At one time I was certified by NASA in mirco solder repair and I can tell you that if you start with a clean solder site (in other words clean it with a stiff brush and alcohol) and a clean soldering iron (in other words the tip is flat and has a thin coat of shiny solder) then you should get quick heat transfer, which will make easy and QUICK removal of the solder and the component from the board - which will in turn limit the chance for damage to the board, the runs or the component.  And of course the same goes for the installation of the replacement part.
So first clean the board where you are going to be de-soldering.
Next quench the soldering iron by rubbing the hot tip over a wet sponge or cloth to wipe away any dull slag and leave a bright conductive tip.
Then just make sure you apply the iron such that it is in contact as much as possible with both the leg of the component which sticks through the hole and the round pad of the run itself at the same time to heat them evenly.  Then watch closely and within a couple seconds the solder joint should go shiny (instead of dull silver) and then right to liquid at which time it can be sucked up with a solder sucker (typically one of those rubber balls and teflon tips).  Once most of the solder is gone you can reheat the pad and component and pull the leg out from the other side.  Repeat the process for the other leg or legs of the component and you are half way done.
Next clean the solder site  and quench the tip again.
Then put you replacement device in so that each leg only sticks about an eighth of an inch through the hole and touch the solder iron to each leg to form a temporary stick bond with the remnant solder on the pad - just to hold it in place.  Then go back to one of the two legs and apply heat to the leg and pad and then touch the solder wire to the opposite side of the pad to let the heat melt it and draw it toward the soldering iron.  You should only put enough solder on the joint so as to form a concave slope up the wire from the edge of the pad.  Most people use far too much solder.
Finally clean the solder join one last time to remove any flux which did not burn off.  Left over flux can corrode joint.
Hope this helps anyone who may have an interest in soldering.
« Last Edit: October 17, 2008, 05:36AM by sderyke2002 » Report to moderator Logged
« Reply #5 on: October 15, 2008, 05:16PM »
Hi NIck.... I appreciate your kind offer to send me work...LOL...however I have a spouse who has me booked solid and I try to go fishing every spare moment I have. There are many well read and knowledgeable people on this site. I have learned much here and I have appreciated the information I gleaned from other well informed people. Take care and regards........  Hondo
spacious_mind
« Reply #6 on: October 15, 2008, 04:51PM »
Hi Hondo,
Wow where are you?  If you are in the States then I am already tempted to send you a couple of my faulty computers to repair
Best regards
Nick
« Reply #7 on: October 15, 2008, 12:49PM »
Tom...without trying to be an "alarmist" the consequence of NOT replacing the "oozing"  cap. might be that the content of the cap. will corrode the circuit board beyond repair and you then have a useless game. To do nothing is sometimes worse than doing something! Most circuit board have caps marked w/ a + or a - to denote which leg of the cap goes where. With that bit of knowledge you now have a better than a 50% chance of getting placement right if you observe the polarity marked on the cap. as well as marked on the circuit board. One other caveat...please make sure the values are the same on the replacement cap and the voltage stated is at least the same if not higher then what was on the old cap. For what my help might be worth....I would be glad to TRY to answer a question if it's w/in the scope of my limited knowledge.
Regards and good luck.....Hondo
« Reply #8 on: October 15, 2008, 12:29PM »
Well, Hondo, I'm glad my theory sounds plausible to ears that are used to technical ideas.
As to the replacing of old capacitors, I could show you pictures of computers in the museum whose capacitors are oozing unpleasant looking fluids. I'm as good as sure that I should replace these components, but being non-technical I tend to have nightmares about having to get them out and solder new ones in on my own
« Reply #9 on: October 15, 2008, 11:02AM »
Hi Tom,
You are absolutely correct.... they do have a positive side ( the anode ) and the negative (cathode) side and again you are correct....reverse the polarity in circuit and you will most likely destroy the cap. Almost all electrolytics depend on internal moisture for their action even though they may be called " dry".  With regard to our discussion electrolytic caps have a dielectric film w/in and their is a school of thought ( so to say ) that this film will dissolve if the capacitor is idle and will reform when power is applied. For the most part this was in reference to high voltage high current draw large caps...and was meant to address and prevent older power supplies that were shut down for extended periods of time....from having these large caps  dry out. I don't think the same applies for our chess games and the small caps w/in them. A lot of heat and age in and of itself will affect caps and can cause leakage and a change in value. But I am not sure it is worth the time and effort to worry about this as it will be many yrs. before that becomes a relevent issue for most games and small electronic devices. Then you just replace the cap w/ the same one and start over. As you...I am also no expert and this has been only my humble opinion.
Best regards to all......    Hondo
« Reply #10 on: October 15, 2008, 09:57AM »
Hi Hondo,
I don't feel offended, so no need for apologies, Hondo   But I don't know enough about electrical components to say anything with any authority about electrical components.
I thought electrolytical capacitors had a positive and negative side. So I suppose if you reverse plus and minus, some chemical action wil damage the capacitor. A circuit that is not used might generate weak currents. So I can imagine that these weak currents can damage the capacitor very slowly, which might be the damage Arno suggests. I can also imagine that a stronger current of the right polarity can undo the damage done by the above-mentioned weak currents - as long as the capacitor has not been turned into a conductor, for then it's too late.
This is what I think may be the reasoning behind Arno's advice, but again, I'm no expert in this field, so I could be completely wrong.
But maybe Google can prove or disprove this theory
With best regards,
« Reply #11 on: October 15, 2008, 08:12AM »
HI Tom....thanks for responding back.... I understand and respect your faith and trust in Arno and I didn't mean to question that...it was simply an attempt to better understand what was being suggested as a preventive measure. I have been in electronics as a repair person and have owned my own shop for many years and the advice given was interesting. Again please accept my apologies if I offended anyone.
Hondo
« Reply #12 on: October 15, 2008, 01:23AM »
Quote from: hondo on October 14, 2008, 08:04PM
I have been following the comments about using chess games in order to "refresh the capacitors"...  there is no doubt that electrolytic capacitors given enough time and heat etc. will dry out and need to be replaced in circuit with another. For my own education is there any chance you could let me in on where I might read the article ( in English ) that indicates that useage of a capacitor will prevent or forstall the eventual drying out process. Plese forgive my ignorance but this is something that I never heard before and I would like to read the technical data/ or article that supports this notion. Thanks.......    Hondo
Hi Hondo,
This is not something that was dreamt up by any member of this forum, but an advice by Arno Kreuzberg, who has repaired hundreds of chess computers. We may safely assume Arno knows what he's talking about. But to be honest, I never took the trouble to verify his findings.
« Reply #13 on: October 14, 2008, 08:04PM »
« Last Edit: October 14, 2008, 08:06PM by hondo » Report to moderator Logged
« Reply #14 on: October 14, 2008, 07:02AM »
Quote from: Steve B on October 12, 2008, 03:28PM
While i agree the advice is sound.. it is hard to do when a collection reaches  enormous proportions like yours
you have more computers in your collection then the days in a year!
so we must modify the advise and say..
for collections of less than 100 schachcomputers:
"chess computers should be used at least once a year in order to keep the electrolytical capacitors in good order
for collections of greater then 100 schachcomputers:
"chess computers should be used when ever at least once a decade  in order to keep the electrolytical capacitors in good order"
Modifying Regards
Steve
Thanks, Steve!
To be honest, I had hoped you'd come up with a solution like some kind of microwave that could refresh the electrolytic capacitors, or some other contraption with artificial - albeit adjustable - hands that could play random games with the computers.
Well, last night I got another one from the shelves as part of continuous efforts to preserve the capacitors of the collection.
With why-did-I-never-think-of-collecting-stamps regards,
Steve B
« Reply #15 on: October 12, 2008, 03:28PM »
Quote from: Overtom on October 12, 2008, 02:58PM
One question which I'm rather curious about: according to Arno Kreuzberg (http://www.elpeon.com/index.php?mod=tipp), chess computers should be used at least once a year in order to keep the electrolytical capacitors in good order. I find his advice not easy to follow.
I understand that you also have a few computers. What do you think about Arno's advice?
With best regards,
Modifying Regards
Steve
« Last Edit: October 12, 2008, 03:29PM by Steve B » Report to moderator Logged
« Reply #16 on: October 12, 2008, 02:58PM »
Quote from: Steve B on October 12, 2008, 03:56AM
[quote author=Overtom]
The number 399 was less inconspicuous, Conchess Ambassador, in good working order, for which Mrs Overtom had to drive me all the way to the swampiest parts of the Low Lands.
Hi Tom
read your blog on the Ambassador
actually Conchess did release modules for the second slot in their boards
they were opening book (Library ) modules
the L0,L16 and Master C6 modules
These modules were used in conjunction with several of the Conchess modules..principally the T6 and T8
here is a photo of the L0 book module locked and loaded(module appears on the left marked with an L:
Double Barrelled Regards
Steve
Thanks, Steve, the info at the museum has been updated.
With best regards,
Steve B
« Reply #17 on: October 12, 2008, 03:56AM »
Hi Tom
Steve
« Last Edit: October 12, 2008, 04:01AM by Steve B » Report to moderator Logged
« Reply #18 on: October 10, 2008, 02:30PM »
Quote from: Mike Watters on October  8, 2008, 03:05PM
That is a classic early chess computer game Tom. When I first read your weblog I remember yelling out at the Senator for **** sake move your queen.
Hello Mike,
Yes I vividly remember your exasperation at witnessing Senator's indecisiveness.
Originally I thought if it was this thread that you were referring to. But I can't find back your colourful words.
By the way, as you predicted, the Overtom Museum did indeed receive its 400th exhibit this week. Unfortunately, it was not a very spectacular acquisition, a black version of Mephisto Beach, a computer that the museum already had in bloodier colours.
There will be no official celebration, but anyone who wants to congratulate the curator will be treated to wine and/or brandy.
With celebratory regards,
spacious_mind
« Reply #19 on: October 9, 2008, 05:21PM »
Hi Tom/Mike,
Assuming that SciSys Executive is identical to the Scisys Senator then sometimes they do find a way to win
[Event "U1400 Green Stage 1 Group M"]
[Site "Active Chess 0:30/1"]
[Date "2008.05.20"]
[Round "17"]
[White "SciSys Executive Chess, LV 3."]
[Black "Novag Alto, LV A3."]
[Result "1-0"]
[ECO "A00"]
[WhiteElo "1000"]
[BlackElo "1300"]
[Annotator "Mind,Spacious"]
[PlyCount "85"]
[EventDate "2008.??.??"]
[EventType "tourn (rapid)"]
[EventRounds "18"]
[EventCountry "USA"]
[EventCategory "6"]
{SciSys Executive Chess has no book} 1. Nc3 {Novag Alto out of book} Nc6 2. Nf3
d5 3. e4 d4 4. Nd5 Nf6 5. Nxf6+ exf6 6. Bc4 Be6 7. Bxe6 fxe6 8. O-O Bc5 9. Qe2
O-O 10. Qb5 Bb6 11. e5 fxe5 12. Nxe5 a6 13. Qe2 Qd5 14. Nxc6 Qxc6 15. d3 Rad8
16. Bg5 Rd7 17. Rfe1 h6 18. Bh4 Re8 19. a4 e5 20. b4 Qe6 21. f4 a5 22. Qf3 axb4
23. Rxe5 Qf7 24. Rxe8+ Qxe8 25. a5 Qa8 26. a6 c6 27. Ra4 bxa6 28. Rxb4 Ba7 29.
f5 a5 30. Rb5 g5 31. fxg6 a4 32. Bf6 a3 33. Ra5 Qf8 34. Qxc6 Qd6 35. Qc8+ Rd8
36. Qxd8+ Qxd8 37. Bxd8 Bb8 38. Bb6 Bf4 39. Bxd4 Bd6 40. Ra8+ Bf8 41. g7 Kh7
42. gxf8=Q h5 43. Qg7# 1-0
That game was played on Level 3.
Nick
« Last Edit: October 9, 2008, 05:27PM by spacious_mind » Report to moderator Logged
