January 29, 2020, 05:41AM
News: Visit a member's site: http://www.pinpoint1.f2s.com/ (Mike Watters)
  Novag Super Expert 96K Adapter
   Author  Topic: Novag Super Expert 96K Adapter  (Read 887 times)
Meca
This is great forum!!
Re:Novag Super Expert 96K Adapter
« on: December 20, 2006, 02:37PM »
  Thank you, very interesting news, I'm sure that this Topic into the Forum will be very useful to much people in the future
« Reply #1 on: December 20, 2006, 05:20AM »
Quote from: Meca on December 20, 2006, 03:07AM
Hi!, I have done the test with a Novag Constellation and it works with a DC unit, but, as I don't know about the electronic world ... Are you sure that we're not going to burn the computer with a DC unit?
Yes; in the worst case, the voltage regulator should work like a fuse...
@bobosse: Are you sure, that 500mA is enough? Normally the "Super"-Novags need 800 mA (according to the sticker on the bottom)
OTOH, i was told, that for an electrician, it should be rather easy, to turn a DC into an AC-adaptor...
« Reply #2 on: December 20, 2006, 04:04AM »
Do not take risk.
It's possible to find some AC unit 9V 500mA for a cheap price. For instance in France:
http://www.gotronic.fr/catalog/transformateurs/transfoframe.php?page_cible=adapt1.htm
model MW905AC for 7,60 Euros
« Last Edit: December 20, 2006, 04:06AM by bobosse » Report to moderator Logged
Meca
« Reply #3 on: December 20, 2006, 03:07AM »
« Last Edit: December 20, 2006, 03:08AM by Meca » Report to moderator Logged
« Reply #4 on: December 18, 2006, 08:15AM »
Quote from: Meca on December 18, 2006, 07:32AM
That's a new for me, Robert, do you mean that a computers with AC power supply may work with an DC adaptor with higher volt?
Correct!
First, i would try it with the same voltage, but if it doesn't work...
Meca
« Reply #5 on: December 18, 2006, 07:32AM »
« Reply #6 on: December 18, 2006, 01:09AM »
Quote from: bobosse on December 15, 2006, 11:38PM
This is a good question.
Did anybody used such high level Novag with a strong adapter (like 1000mA) at 9V or 7,5V ?
Does it work or does it really requires a 8,5V ?
No; the common voltage regulators can manage much higher voltages.
If you don't find a matching AC, I would try a DC-adaptor with >1000mAh. If it doesn't work with 9V, try 12V. Works here without problems!
AC devices often need a higher DC voltage than they need as AC. Had this with a Super Forte C 6 MHz: Did not work with 9 V DC (pale LCD and hangups after some moves); but with 12 V there was no problem anymore!
« Reply #7 on: December 15, 2006, 11:38PM »
Meca
« Reply #8 on: December 15, 2006, 11:06PM »
I think you need  an AC Output adaptor. There're universal ones for laptops that gives you AC output. If you don't find one you'll have to go to an electronic warehouse.
One idea more, the constellation, super constellation, superforte, scorpio and diablo chess computers works with the same adaptor. You can look for a Constellation with the power supply unit in ebay  unit for not a high amount.
pawnstormca
« Reply #9 on: December 15, 2006, 08:18PM »
I recently acquired a Novag Super Expert 96k chess computer in but I can't use it since I don't have the adapter. Does anyone happen to know where I can buy such an adapter? It is such an usual voltage ( 8.5v 800mah) that none of the current adapters or universal adapters appear to support it.
If anyone has any information about this, I would sincerely appreciate them letting me know. Thank you.
