July 7, 2020, 11:42AM
News: Map of chess computer friends: http://www.frappr.com/chesscomputers
  Super Forte problem
   Author  Topic: Super Forte problem  (Read 969 times)
Antonio Marques
Re:Super Forte problem
« on: December 21, 2006, 01:06PM »
Hi!
The electronic component that it needs to be swap to change clock is of the photo?
http://www.schach-computer.info/wiki/index.php/Bild:SchachschuleII-Platine2.jpg
Which computers you made overclocking? They somebody has some experience with the H8 processors?
[]s
Antonio Marques
gallux1
« Reply #1 on: December 21, 2006, 09:19AM »
Quote from: Chest-Nut on December 21, 2006, 07:21AM
This is interesting, to reclock to a faster speed.  Is it some thing easy to do?  And Gallula, did you put it back to 7.5 and do a reset?
Chest-Nut
Oh NO friend,I dont put its back !
In fact,some cpu (here 6502) accepts a little tuning;I just change the quartz (from 12 Mhz to 15 Mhz here)
I have an other SF C which runs very well at 8mhz (quartz 16 Mhz; I cross my fingers and thanks Stefan!)
Chest-Nut
Chest Nut
« Reply #2 on: December 21, 2006, 07:21AM »
Chest-Nut
Chest-Nut
gallux1
« Reply #3 on: December 21, 2006, 05:40AM »
Quote from: Robert Weck on December 21, 2006, 05:31AM
Quote from: gallux1 on December 21, 2006, 04:12AM
Incredible ,after the reset,the computer now reply error but I can access to the key and I can enter E2 E4;,I turn off  again the computer and then here,it plays H2 H4 and E7 E5  alone ??
Maybe the EPROMs are damaged? can you replace them?
You are using the same adaptor as before?
I am going to do what you are saying.Make a rest to the SF.
Thanks again Robert!
P.S.: Or what might help: do a reset and let it off for one day; i often heard, that computers could be revived this way (not only with chess computers (i had a similar experience with my SuFo and Super Constellation), but with some PDAs, that worked again after a day of "rest"
« Reply #4 on: December 21, 2006, 05:31AM »
gallux1
« Reply #5 on: December 21, 2006, 04:12AM »
Quote from: Robert Weck on December 21, 2006, 12:37AM
Quote from: gallula on December 20, 2006, 11:17PM
And now    ,after the normal  answer of the computer : 123456789 and a BIP,when I push on GO or NEW GAME.
There is nothing  also when I try to play E2 E4 (pushing on these cases to enter my first move).
Have you tried a reset? Just a little reminder: Turn the SuFo off, push the reset-switch to position "Reset" for 10 seconds, back to "Normal" and then power it on again!
good luck!
Hello Robert,
Thanks again for your help Robert!
« Reply #6 on: December 21, 2006, 12:37AM »
good luck!
gallula
« Reply #7 on: December 20, 2006, 11:17PM »
My first message disappeared ...
Hello,thanks for your help again!
I just overclocked from 6 to 7,5;but now,I put back the
original  6 Mhz.
Thanks for your help and suggestions!!
MY BEST!
gallula
« Reply #8 on: December 20, 2006, 03:07PM »
original  6 Mhz.
Meca
This is great forum!!
« Reply #9 on: December 20, 2006, 02:46PM »
The new clock, how many MHZ has? Have you burned a little the main board? Can you post a photo of the main board here? It could be useful
gallula
Super Forte problem
« Reply #10 on: December 20, 2006, 01:53PM »
Hello Friends,
Could you please help:
I overclocked my Super Forte ;and now when I put on my chess computer,it indicates 123456789 and after there is a bip to begin the game BUT,after that, when I push on "GO"  or "New Game" ,there is no answer.
and also if I want to beginthe game, for example :e2 e4 here also the Super Forte  does not answer .
After putting back the original quartz,there are no changes.
Someone has got an idea?
Thank you for your answers!
