July 15, 2019, 12:06PM
News: Chess Computers Revolution DVD documentary: www.ismenio.com/chess_dvd.html
  Mephisto Mobil - any incompatible cartridges?
   Author  Topic: Mephisto Mobil - any incompatible cartridges?  (Read 725 times)
spacious_mind
Re:Mephisto Mobil - any incompatible cartridges?
« on: May 24, 2007, 04:42AM »
Quote from: Alain Zanchetta on May 23, 2007, 10:53PM
I am pretty sure that my Rebel module also work.
I thnk you might be correct with the Rebel working, I think I saw in someones Aktive ELO List Rebel Mobile mentioned recently.
Quote from: Robert Weck on May 24, 2007, 12:37AM
But it says nothing about Rebel 5,0, B&P or MM II (IIRC somebody wrote in another forum, that MM II would not work in a Mobil, but i cannot confirm this at the moment)
I can confirm that MMII does not work inside my Mobils
rgds
Nick
« Reply #1 on: May 24, 2007, 02:39AM »
Hi Robert,
By the way, I think that there is may be another thing to take into account : there are two different Mobil : one with an LCD display, and the other without. I don't know if this second one has an "red digits" display or not : it seems so but mine does not display anything.
No, that display (or should i better say "window"? ) is just blackened; H&G just used the same case as the LCD-Mobil has. It can only be used with the Mirage module, as this has its own display.
Thanks for the precision ! So now I know that my two Mobile are working.
« Reply #2 on: May 24, 2007, 12:37AM »
If you put a Mirage module in a LCD-Mobil, then you see the moves twice!
No chance for a Polgar: Only modules, that need a 7-segment LCD work in a Mobil.
Here is a list of working modules:
http://www.schach-computer.info/wiki/index.php/Mephisto_Mobil
« Reply #3 on: May 23, 2007, 10:53PM »
So, I cannot put the same modules in both Mobil : I only can put modules with a display in one, and the other accepts the modules where the moves can be keyed in.
« Reply #4 on: May 23, 2007, 06:47PM »
Hi Nick,
Many thanks for the info. I'll pass it along to our visitor.
spacious_mind
« Reply #5 on: May 23, 2007, 03:44PM »
Ismenio:
The only ones that I think work on the Mephisto Mobil are:
Mirage
MM I
MM IV
MMV
Roma II
Other than the above I do not think others work.  I tried on mine to see if others work the  Polgar and MM II and they wont even side fully into the Mobil  Unit.
rgds
Nick
« Reply #6 on: May 23, 2007, 10:06AM »
Hi All,
I'm trying to help a visitor so I'm posting her question here.
Is there any Mephisto cartridge that does NOT work on a Mephisto Mobil unit?
