April 25, 2019, 07:44AM
News: Visit a member's site: http://www.schachcomputer.info/ (Chessguru)
  Novag Chess Clock Cable
   Author  Topic: Novag Chess Clock Cable  (Read 761 times)
Re:Novag Chess Clock Cable
« on: June 16, 2008, 05:31AM »
I don't know specifically but if a standard phone wire will not work then I would guess it is what is called a null modem wiring.
In that there is a crossing of the transmit and receive wires at opposite ends - as you can read about and see at this link:
http://www.lammertbies.nl/comm/info/RS-232_null_modem.html
(Note: the top most diagram is the one you want to model your wire off of since it is the four wire variety)
I doubt there is any way trying this could hurt your equipment but if you are nervous it might be best to hear from someone here who has looked at the wire and knows for sure.
« Last Edit: June 16, 2008, 05:32AM by sderyke2002 » Report to moderator Logged
marko
« Reply #1 on: June 15, 2008, 08:26PM »
Does anyone happen to know how the wires are connected on the cable that comes with the Novag Chess Clock? According to an earlier post by Mike Watters,  the cable looks similar to a standard telephone cable. It is about 40 cm. long with identical telephone connectors at both ends. There are six wires. It was made by OKI. Any help would be appreciated. Many thanks.
Marko
