June 6, 2020, 07:40AM
News: Visit a member's site: http://www.elpeon.com/ (Jose)
  Novag Scorpio
   Author  Topic: Novag Scorpio  (Read 1215 times)
Re:Novag Scorpio
« on: June 27, 2008, 10:16PM »
Hi Jose,
Quote from: Jose on June 27, 2008, 01:40PM
perhaps can Arno help you?
Did you ask him?
thanks for the suggestion ! Anyway, I gave it back to the seller...
Jose
Time to play Chess!
Re:Novag Scorpio
« Reply #1 on: June 27, 2008, 01:40PM »
Hi Alain,
Did you ask him?
Hope all will best Regards José
Re:Novag Scorpio
« Reply #2 on: June 22, 2008, 04:04AM »
Hi Olivier,
Quote from: mychess on June 21, 2008, 07:39AM
A point of view programmer :
- tired keyboard : the pressed key returns to its no contact state after a random delay.
  The computer awaits this no contact keyboard by waiting.
The problem could finish with time (the  supple of the keyboard get back).
- Modified computer, with synchronous problem between memory and CPU .
I Hope that this can help you.
Mychess.
thanks for the ideas, I think that the answer is closer to solution #2 than #1. It never hangs after I press on the first square, and for castle, it also always hangs between third and fourth square.
Re:Novag Scorpio
« Reply #3 on: June 21, 2008, 07:39AM »
Hello Alain,
Mychess.
Novag Scorpio
« Reply #4 on: June 20, 2008, 12:34PM »
I have bought a Novag Scorpio but it does not seem to work fine, althought it does not seem to far...
Very often when I finish to enter my move, for example e2 e4, the LEDs stay on and the display stays on "e2 e4" for quite a long time before the computer changes the display to show the clocks and starts to think.
In the case of a king side castle, it hangs after I press h1 and waits before turning the f1 LED.
This delay varies from a few seconds to almost two minutes.
I have tried to change levels, to do a reset but it does not change anything.
Has anybody seen such symptoms ?
Thanks in advance,
