April 22, 2019, 08:00AM
News: Visit a member's site: http://www.meca-web.es/ (Meca)
  Are electronic chessboards hybrid computers?
   Author  Topic: Are electronic chessboards hybrid computers?  (Read 668 times)
Re:Are electronic chessboards hybrid computers?
« on: October 13, 2008, 10:05AM »
My SolarStar is also hybrid because it works on battery or solar cells
So it uses an hybrid source of energy.
yano1966
« Reply #1 on: October 12, 2008, 01:30PM »
Hello Tom
In the direction of the electronic language your chess computer is NUMERICAL 100%… (according to my way of seeing)
Hybrid concept - > analogical/numerical actually applies to any type of machine able to treat an analogical signal, to sample it, and to convert it into numeric signal…
Like this :
The curve is the analogical signal, the histogram is the numeric copy (like a Tuner hydrid for numeric and analogic TV channels).
In your case, the sensors of the chess-board detect only the presence or the absence of pieces (system “all or nothing”). binary data thus numerical!
Not the analogical one in all that. It would be necessary (for example) that the chess-board detects the force with which you cheeks a pawn to have analogical information…
Tom
« Reply #2 on: October 12, 2008, 10:33AM »
When considering the adjective "hybrid" this afternoon, just because it came across my way, I thought to myself that an electronic chess board like my Mephisto Atlanta is a hybrid computer, too, isn't it?
"Hybrid", explained in simple words, means that two different systems are united in one case. For example, a hybrid computer is a computer, which consists of an analog part and a digital part. The analog part measures data and passes them on to the cpu where the analogously detected data are processed digitally and the results are put out in digital or analog form. Another example is a modern library where there are real books with real pages and digitally scanned books which you can read only on screen. This is a hybrid library. It contains two different kinds of libraries under the same roof, in the same building.
My chess computer also has both an analog and a digital part. The analog part is the board with its chessmen which stand on this or that square. The information about the pieces are sent via sensors to the processor which handles them digitally and puts out the result partly digitally (display) and partly analogously (blinking red small lamps).
So my Atlanta is a real hybrid computer, right?
« Last Edit: October 12, 2008, 10:37AM by Tom » Report to moderator Logged
The secret of freedom is courage!
(by Perikles, the great leader of Athens, 490-429 B.C.)
