July 6, 2020, 05:45AM
News: Visit a member's site: http://www.izarlili.com/ (Kalikolo)
  Polgar Beep Sound going out
   Author  Topic: Polgar Beep Sound going out  (Read 847 times)
Blitzkrieg-Burritomeister
Re:Polgar Beep Sound going out
« on: February 8, 2009, 10:15AM »
Update:
    This had a happy ending by soldering a loose connection of the 2 leads of the piezo beeper to display board.
    JG
« Reply #1 on: January 31, 2009, 06:36AM »
Quote from: Endspielgott on January 31, 2009, 06:15AM
Quote from: johnnygar on January 29, 2009, 03:45PM
I'm beginning to believe the Munich board issue will get resolved....However I have another hopefully small issue and that is my 5 mhz Polgar unit is for the most part losing its beep ability, which means you have to look around abit more and hopefully that is all.
    Is this fixable? And is this a bad sign?
  JG
HI Christian
    And thanks to youf or the info. I will go to the hardware store and get a soldering iron . How about getting in to the polgar modual? You think fairly simple?
  Thank
  JG
John,
its fixable with a soldering iron. Sound comes from a piezo which can easily be replaced. Spare parts worth is less than 5$. The piezo is located in the display module.
« Reply #2 on: January 31, 2009, 06:15AM »
  JG
John,
« Reply #3 on: January 29, 2009, 03:45PM »
HI Christian
  Thank
  JG
« Last Edit: January 31, 2009, 06:38AM by johnnygar » Report to moderator Logged
