June 25, 2019, 11:37AM
  magnet strength
   Author  Topic: magnet strength  (Read 665 times)
exabyte
Chess is the Best
Re:magnet strength
« on: February 20, 2009, 09:00AM »
Thanks Terry.
Re:magnet strength
« Reply #1 on: February 20, 2009, 02:33AM »
Dear Excabyte,
                              If you are worried about the magnets damaging the reeds, well I can assure you no harm will come to them. When I was a telecom engineer we used these in there millions and although occasionally they failed they can stand up to quite high voltage and at very fast speeds. The occasional failure I have had on my Mephisto exclusive is down to wear and tear or the odd rogue reed. Quite often the LED or blocking diode will fail when the reed is fine.
            regards,
                              Terry
exabyte
Chess is the Best
Re:magnet strength
« Reply #2 on: February 19, 2009, 05:46PM »
Thank you.
Re:magnet strength
« Reply #3 on: February 19, 2009, 01:21PM »
don't know what Baron uses, but have used the K&J magnetics neodymium disc magnets in pieces for the Citrine, Leonardo, exclusive, grandmaster etc. the type "N" 3/8 by 1/16 work fine with all these machines for years 1/16th deep hole ,mount flush and covered with felt. never had a problem with any reed switch being over stressed. I did alot of testing with different discs to come up with that one and the field strength seems about perfect.  regards, Tony
exabyte
Chess is the Best
magnet strength
« Reply #4 on: February 19, 2009, 07:22AM »
I recently purchased the enhanced pieces for my Citrine.  I noticed that they fit beautifully with my Elite A/S Challenger, but I am concerned about the strength of the magnets.  Obviously, if it is too weak, they won't work, but if the magnets are too strong, could it damage the switches in tha A/S board?  Thanks.
