January 26, 2020, 06:59AM
  How to distinguish a Mephisto IX, 2 and 3
   Author  Topic: How to distinguish a Mephisto IX, 2 and 3  (Read 747 times)
Steve B
Re:How to distinguish a Mephisto IX, 2 and 3
« on: May 19, 2009, 11:20AM »
Sadly..as luck would have it.. while i have an English manual for the Mep II and Mep III.. I only have a German manual for the Mep I
i will double check this evening however and post again if i find an English one
Regretful Regards
Steve B
chubbyupchuck
« Reply #1 on: May 19, 2009, 11:12AM »
Blimey, I would never have thought it was so complicated.  So, a follow up question.  My Mephisto I, IIb did not come with a manual.  I can see German and French manuals for the Mephisto I, IX and II on Eric's site.  Given my Mephisto is a I, IIb which manual do you think is the most appropriate to consult?  And does anyone know if an English language version exists?
Thanks for your continued patience.
Chubby
Steve B
« Reply #2 on: May 18, 2009, 04:02PM »
I just checked my ESB II module in the special Esb II Brikett
the Esb II module will only work in this Brikett(and in the ESB II wooden board of course)
this brikett is the same as Chubby's and Erics version II brikett
that is to say..it is a Version II Brikett with no arrow keys and no white and black boxes
Probing Deeper Regards
Steve
« Last Edit: May 19, 2009, 04:25AM by Steve B » Report to moderator Logged
Steve B
« Reply #3 on: May 18, 2009, 11:21AM »
Perhaps Eric
i know my version II brikett came with the Mephisto II program module and it was the normal 3.5 Mhz(bought new when released for sale)
my Mephisto III program module came in the Version III Brikett and runs at 6.1Mhz(bought  new when released for sale)
The Plot Thickens Regards
Steve
« Last Edit: May 18, 2009, 11:23AM by Steve B » Report to moderator Logged
blitzchess
« Reply #4 on: May 18, 2009, 11:13AM »
Steve,
a version without White-Black keys is a Mephisto II 3.5 MHz and the other version is a Mephisto II at 6.1 MHz.
Is this a coincidence?
Best regards
Steve B
« Reply #5 on: May 18, 2009, 10:52AM »
Hi Eric And Chubby
interestingly ...
it seems Eric's version II brikett also does not have the square boxes(White-Black keys)
perhaps there are TWO version II Briketts??
a version II(a) and a version II(b)
if so ..we can now say you have a Mephisto I Program module and a version II(b) Brikett
II(b) or not II(b) Regards
Steve
« Last Edit: May 18, 2009, 10:54AM by Steve B » Report to moderator Logged
blitzchess
« Reply #6 on: May 18, 2009, 09:48AM »
Hello Steve and Chubby
Here is a picture of Mephisto 1X
http://www.blitzchess.fr/fr/images/mephisto1x.jpg
and details of other "briketts"
http://www.blitzchess.fr/fr/jeuxdes7familles/mephistohg/briquette/default.html
Best regards
Eric
chubbyupchuck
« Reply #7 on: May 18, 2009, 07:19AM »
Hi Steve,
Thanks for the blindingly quick response.  So it looks as though I probably have a Mephisto I program module, perhaps with a Mephisto II brickett.  The brickett does not have arrows, in fact it also does not have the square symbols on the 9 and 0 keys visible in...
http://www.flickr.com/photos/10261668@N05/859058524/in/set-72157600922171154/
If anything the 9 and 0 keys are more like those on the Mephisto I visible here...
http://www.flickr.com/photos/10261668@N05/858180707/in/set-72157600922171154/
Although as I mentioned I also have standby switch rather than the grille visible in this photo.
Nice set of photos by the way, very helpful.
Chubby.
Steve B
« Reply #8 on: May 18, 2009, 05:55AM »
Hi Chubby
actually your question is not naive because the different Briketts and program modules can be quite confusing
first of all ..please be aware that ALL program modules can be used in all Briketts(the ESB II program module is a special case not discussed here)
that is to say.. the Mep I,II and III program modules can each be used in the three different briketts
now...the II and III program modules had the words..Mephisto II(III).. engraved on the back of the modules while the Mephisto I had nothing written.
so my guess is you have a Mep I program module
as to the Briketts
as you mentioned ..since you have the standby switch this eliminates the Brikett version I
To determine if you have a Version II or version III brikett
look to see if you have ARROWS on the 9 and 0 keys
if so.. you have a version III Brikett
if no arrows.. a version II Brikett
you can see the differences between the two Briketts here:
Version III Brikett:
http://www.flickr.com/photos/10261668@N05/858172011/in/set-72157600922171154//
Version II Brikett:
Thick As A Brikett Regards
Steve B
« Last Edit: May 18, 2009, 07:01AM by Steve B » Report to moderator Logged
chubbyupchuck
« Reply #9 on: May 18, 2009, 05:26AM »
Please excuse my naive question.  I have purchased a Mephisto brick.  However, I am not sure which version it is.  It has a replaceable program module and standby switch which I think discounts it being a Mephisto 1.  I cannot see any module numbers on the program unit, as described by Overtom, so I thought it was a 1X.  However, the model number on the unit and program module is DH4005 and Googling this throws up an auction for a Mephisto 2.
Thanks for any help.
Chubby
