August 8, 2020, 07:24PM
  MM II
   Author  Topic: MM II  (Read 930 times)
Re:MM II
« on: October 28, 2009, 10:58AM »
Hi Steve, any idea why they left it out of the MM series? Just curious, thankfully its not that hard to set up position where you left off. the only problem is that the clock is then reset which gives a advantage to the MM if its playing another computer that saves the game and remaining time. I see no work around for that except to play the game with no breaks. agree?  Tony
Steve B
Re:MM II
« Reply #1 on: October 27, 2009, 01:35PM »
Well in the MM series it took that long
of course Mephisto released many different models other then the MM Series and the feature was included in many of them
Steve B
Re:MM II
« Reply #2 on: October 27, 2009, 01:30PM »
thanks for the info, didn't know it took that long for mephisto to add that feature.  regards, Tony
Steve B
Re:MM II
« Reply #3 on: October 27, 2009, 12:48PM »
Hi Tony
Sadly in the  Mephisto MMII-V Series there is no Cmos Memory so its not possible to save the game,level settings or any other settings when the computer is turned off
the feature first appeared in the  MMVI
Amnesia Regards
Steve B
« Last Edit: October 27, 2009, 12:49PM by Steve B » Report to moderator Logged
MM II
« Reply #4 on: October 27, 2009, 09:32AM »
Is there a way to save a game in progress, to continue later? No mention in my manual, but it is a copy. Even my brick Mephisto II has a standby switch. I can't believe they would leave out this option. regards, Tony
