April 10, 2020, 11:14AM
News: Visit a member's site: http://overtom.nl/ (Overtom)
  RE: Atlanta Repair
   Author  Topic: RE: Atlanta Repair  (Read 1634 times)
RE: Atlanta Repair
« on: April 25, 2010, 04:18AM »
Hi Larry,
no sorry to disappoint you. I am German and by 10 years younger than him
And I have never been any good at programming.
The first name seems to be the only thing he and me have in common.
Quote from: Larryh71 on April 24, 2010, 08:12PM
Hi Christian, are you by any chance, Christian (Chrilly)
Donniger,?...just wondering...
« Last Edit: April 25, 2010, 04:21AM by Endspielgott » Report to moderator Logged
Larryh71
RE: Atlanta Repair
« Reply #1 on: April 24, 2010, 08:12PM »
Quote from: Endspielgott on April 24, 2010, 11:45AM
Quote from: Larryh71 on April 22, 2010, 02:20AM
Keep the Atlanta for a pet...
all the best,
Larry
Hi Larry,
at least this "pet" won´t be alone...with three Risc 2500 as friends...
Best wishes
all the best
Larry
Procrastinate now!
RE: Atlanta Repair
« Reply #2 on: April 24, 2010, 11:45AM »
all the best,
Larry
Hi Larry,
Best wishes
Larryh71
RE: Atlanta Repair
« Reply #3 on: April 22, 2010, 02:20AM »
Quote from: Tom on April 20, 2010, 01:15AM
@Larry: It seems to me that your problem mentioned in this thread
http://users.boardnation.com/~chesscomputers/index.php?board=1;action=display;threadid=1468;start=0
has been solved now.
Sometimes things take some time.
Regards,  Tom
Hi Tom, yep it's fixed now, over two years later
While it niggled me, it did'nt affect the machine's operation.
In any case, the Atlanta plays too darned strong, I actually
enjoy a casual game against the humble Fidelity SC9. Keep
all the best,
Larry
Procrastinate now!
RE: Atlanta Repair
« Reply #4 on: April 20, 2010, 01:15AM »
Regards,  Tom
« Last Edit: April 20, 2010, 01:16AM by Tom » Report to moderator Logged
The secret of freedom is courage!
(by Perikles, the great leader of Athens, 490-429 B.C.)
thx1138
RE: Atlanta Repair
« Reply #5 on: April 15, 2010, 08:36PM »
    Thanks for your help Larry and Robert. I really
    appreciate it.
                              Martin
Larryh71
RE: Atlanta Repair
« Reply #6 on: April 14, 2010, 04:00AM »
Quote from: Larryh71 on April 14, 2010, 12:15AM
... and when you get it open, you will find the flat ribbon leads
going from the mainboard to the underside of the playing
surface. Just gently pull them loose and re-insert them. My
guess is that you have a simple oxidation problem, and this
easy procedure will cure it.
  hope it works out ok...
  Larry
  Well as an add on to my last post on this matter, this has
inspired me to fix an annoying glitch in my own Atlanta. Since
I've owned it the 'pawn' icon has not shown. I took the back
off and found the problem...a bit of sticky goo on the contact
of the mainboard. I just removed it and...*presto*... the
Atlanta is fixed.
  I'll sleep better now,
  Larry
Procrastinate now!
Larryh71
RE: Atlanta Repair
« Reply #7 on: April 14, 2010, 12:15AM »
Quote from: Robert Weck on April 13, 2010, 11:34PM
Hi Martin,
remove the rubber feet; the remaining 3 screws are there.
regards,
  Larry
Procrastinate now!
RE: Atlanta Repair
« Reply #8 on: April 13, 2010, 11:34PM »
Hi Martin,
Quote from: thx1138 on April 13, 2010, 10:55PM
        The sensory squares on my Atlanta recently
        stopped working.  I haven't been able to open
        it up to see what the problem might be. I removed
        1 screw in the battery compartment, but didn't see
        any others. I'm not sure if you're suppose to pull
        it apart to open it, but I'm afraid to force it open.
        Does anybody know how to open an Atlanta up?
        Or what might be causing the sensory squares not
        to work?? Thanks for any help anybody can offer...
regards,
thx1138
RE: Atlanta Repair
« Reply #9 on: April 13, 2010, 10:55PM »
        Martin
