March 23, 2019, 10:49PM
News: Visit a member's site: http://www.schachcomputer.info/ (Chessguru)
  Novag Citrine reset button
   Author  Topic: Novag Citrine reset button  (Read 1289 times)
Re:Novag Citrine reset button
« on: July 3, 2011, 12:06PM »
Bryan is right, return it as fast as you can for a replacement. I don't think Novag has a very long warrentee. although some sellers have their warrentee like "classic chess and games" will warentee for at least a year if not more. regards, tony
Mephisto
« Reply #1 on: July 2, 2011, 07:37AM »
Just ask for a replacement under it's warranty.
I don't think your problems will be solved by just resetting the Citrine.
Bryan
« Reply #2 on: July 2, 2011, 01:05AM »
You are not lucky.
Such kind of problem is uncommon.
but sometime, electronic components have a very short life.
netxshare
« Reply #3 on: July 1, 2011, 08:53PM »
Thanks for the reply, but I have looked on the bottom of the chess board and there is no hole or anything. From what I can tell the only way to access the reset button on my system is to unscrew the back panel.
http://img465.imageshack.us/img465/7268/novagdet2clockosciladorxd2.jpg - this is the only picture I could find of the reset button online.
anyways, the issue I am having is after a day of playing with my brand new Citrine, square F1 no longer detects a piece on it, and only two out of four LED's light up, the LCD displays UEr F1. Which from what I have read means it's waiting for that piece. Also when I have a piece of E1 only three LED's light up, the bottom right which is used for F1 fails to light up. I am guessing the unit is broken and just needs to be sent back. This is rather disappointing.  Do Citrine's fail often?
b4xter
« Reply #4 on: July 1, 2011, 01:17PM »
You can find the reset button under the computer. There is a very small hole on the veneer, without any mark or label - surpisingly the reset button is under this hole. Try to push it with a pin or other sharp object. Good luck!
Tibor
netxshare
« Reply #5 on: June 30, 2011, 11:15PM »
I just got a Novag Citrine and after a day of use it seems that the F1 square is not detecting a piece, the LCD says UEr F1, which I know is the verify mode. I read in the manual that there is a reset button on the back of the computer, I can not find this any where. Can someone explain where it is or take a picture for me. I am hoping that the reed switch is just stuck and that the Novag Citrine is not broken.
