May 22, 2019, 10:50AM
News: Mirror of the old site for Tasc.nl at www.chesscomputers.org
  Novag 2Robot Arm Enable/Disable?
   Author  Topic: Novag 2Robot Arm Enable/Disable?  (Read 5266 times)
Re:Novag 2Robot Arm Enable/Disable?
« on: April 23, 2013, 06:52PM »
I have the same problem that you have, I haven't found a way to enter any kind of "options" mode where Takeback could have a different behavior.
KingAlbert
« Reply #1 on: April 19, 2013, 09:43AM »
Does anyone know how to enable/disable the Novag 2Robot so that it can play without the arm movement, i.e., display its moves only on the LCD?  The manual has the following paragraph:
ARM MOVEMENT ENABLE/DISABLE
The 2Robot arm movement can be enabled or disabled by the toggling the TakeBack key to "Robot =" or "Robot ".
However, using the "TakeBack" key does not work, as it only results in actually taking back moves (duh) or an "Error" message at the beginning of a game.
