January 29, 2020, 01:16PM
  Novag Obsidian
   Author  Topic: Novag Obsidian  (Read 819 times)
Re:Novag Obsidian
« on: June 6, 2005, 01:45AM »
Hello Ajax,
Quote from: Ajax on June  6, 2005, 12:35AM
Does anyone own the Obsidian? Any opinions?
I have the Emerald Classic plus, which seems to have the same program, but slightly slower (26,6 Mhz; the O. has 2x16 MHz)
I would estimate his strength at about 1950 (old) SSDF-ELO; somewhere in the range of MM V, Polgar and so on.
It plays interesting and active; there is only one thing, I don't like: the display is too deep in the case, so it is not very good to read. But I don't know, how this is at the Obsidian; maybe they have changed it...
Oh, and another little problem, which I discovered: the Average-Time-levels are not working correctly (the Emerald cl. plus uses much to less time with them!)
At level "AT9" he took about 9sec/move (should be 75!); at level "AT11" about 24sec/move (should be 100!)
The Sapphire/Diamond has a similar problem IIRC...
hope that helps,
Ajax
Novag Obsidian
« Reply #1 on: June 6, 2005, 12:35AM »
