July 11, 2020, 01:03AM
News: Visit a member's site: http://zanchetta.net/echecs/  (Alain Zanchetta)
  Senator module and repetition draws
   Author  Topic: Senator module and repetition draws  (Read 1236 times)
Re:Senator module and repetition draws
« on: January 18, 2006, 02:16AM »
Quote from: PaulM on January 16, 2006, 07:06PM
The program immediately showed Qg5 when I hit the [info] key.  It never wavered from that candidate move until it finally played it.
the same here with my Milano pro! On 30min/game he played Qg5 after <1 min.
Ernest Gundel
« Reply #1 on: January 16, 2006, 09:09PM »
I'm guessing the problem may be the result of the Senator's relationship with it's big brother the Magellan, which has a slightly faster clock speed and (more importantly) a hash table.
I suspect the repetition recognition logic included the hash table. Every position in a game thus far would be inserted in the hash table with a value of zero, so if a search found that position, it would recognize it as leading to a draw. Maybe Saitek simply removed the hash table without putting in some other kind of logic to recognize draws.
exabyte
Chess is the Best
« Reply #2 on: January 16, 2006, 07:06PM »
Hi Jaco,
Regards
Paul
Jaco
« Reply #3 on: January 16, 2006, 11:38AM »
Hi Paul,
Did your Mephisto Master immediately show Qg5 as the response (if you press "info" button while computer is thinking) or does it only switch to Qg5 later (you mention it played Qg5 after 6:30 only). I'd like to know whether it was considering another move before it chose Qg5.
In the case of my Mephisto Chess Challenger, the computer immediately chose Qg5 as it's favourite move, and never deviated from it - that shows that it immediately recognised the repetition draw from King moves.
Yes, you are correct in that the Master and the Senator use identical hardware and identical programs - that could mean that a mistake slipped in somewhere in the compilation of the senator's software.
I'm going to email Saitek on this issue (yeah right, as if I'm expecting to hear anything from them on this). But what the hell, let's at least see what they say :-)
Jaco
exabyte
Chess is the Best
« Reply #4 on: January 16, 2006, 09:00AM »
In this position the Mephisto Master(Milano Pro which I thought was the same as the Senator module) after 6:30, the computer played Qg5.  Maybe it's not the exact same program.
drawmeister
How about a nice game of chess ?
« Reply #5 on: January 15, 2006, 12:51PM »
Jaco,
No problems with the Magellan, as fast as i could see the info display it was showing Qg5 and giving itself a nice + 4.0 evaluation  .
It would be interesting to see if any other computers are reluctant to give up their Queen and are fooled by this position. I will try it on some others.
Very interesting.
Ian.
Jaco
« Reply #6 on: January 15, 2006, 07:05AM »
Hi Ian,
Steve Blincoe confirmed to me earlier today that his senator module makes exactly the same mistake - I think we can take it for granted that there is a bug in the senator.
Yes please do test it on the Magellan. Given that the Magellan and the Senator are supposed to run identical programs only on different hardware, it will be interesting to see what happens.
Jaco
drawmeister
« Reply #7 on: January 15, 2006, 05:51AM »
That is very poor for the Senator not to play Qg5, especially as it is quite a highly rated machine.
I will try the same position out on it's big brother the Magellan......i will be amazed if it misses it too    !!.
This is a nice position to test on other computers.
Ian.
Jaco
« Reply #8 on: January 14, 2006, 12:19PM »
Excellent position Ernest.
I tested it on my Mephisto Chess Challenger and on a Mephisto Senator Module (in an Exclusive Board).
The Chess challenger responded to 1. Rg2+ with Qg5 almost immediately.
The Senator on the other hand allowed the repetition draw, irrespective of the amount of thinking time allowed. It evaluated the position as about a 7 pawn advantage for black the entire time.
It would be interesting to see if other senator owners get exactly the same result. If so we might have uncovered a pretty obvious bug in the senator modules.
Jaco
« Reply #9 on: January 13, 2006, 04:58AM »
I don't think it's only Senator that suffers from this ailment. I even wonder if it is a general problem with Mephisto Saitek computers.
Could the senator be made by the same programmer who had a hand in programming the Saitek Mephisto Maestro and the Saitek Mephisto Chess Challenger?
I found that the latter computers also had a fatal tendency to draw where they could easily have won.
I described a few games with this feature in some detail at:
  http://www.xs4all.nl/~tluif/weblog/13FEB05.html
  http://www.xs4all.nl/~tluif/weblog/13NOV04.html
« Reply #10 on: January 12, 2006, 11:20PM »
Quote from: Ernest Gundel on January 12, 2006, 05:55PM
I don't have any such games saved, but it's pretty easy to find a position where the Senator draws by repetition when it could easily win by making a small sacrifice. For example, black should easily win the following game:
CAPS ARE WHITE, lowercase are black
8| .  .  .  b  .  r  k  . |
7| .  R  .  .  .  .  .  . |
6| .  .  .  .  .  p  .  . |
5| q  .  .  .  .  .  .  . |
4| .  .  .  .  .  .  .  . |
3| .  .  .  .  .  .  .  . |
2| .  .  .  .  .  .  .  R |
1| .  .  .  .  .  .  K  . |
  A  B  C  D  E  F  G  H
white to play
Thanks, i will test it!
Ernest Gundel
« Reply #11 on: January 12, 2006, 05:55PM »
  A  B  C  D  E  F  G  H
white to play
« Reply #12 on: January 10, 2006, 03:44AM »
Quote from: Ernest Gundel on January  7, 2006, 09:54PM
I noticed exactly the same thing with my Senator. It plays a very good game in general, but doesn't pay any attention to whether it is repeating moves until it has already drawn.
I find it difficult to understand how it could have such an obvious programming error. Even old machines I used 20 years ago, like the MM3 Rebel module, or the Novag Forte, wouldn't allow such bad draws.
Just fixing this one problem should give the Senator a 100+ bump in it's rating.
I have a Milano pro (the stand-alone version of the Senator Module), but have never seen this happening before!
Do you have the notation or the final moves and position of such a game?
Would be very interesting for me, if it is possible to repeat this with a Milano pro...
thank you,
Ernest Gundel
« Reply #13 on: January 7, 2006, 09:54PM »
Jaco
« Reply #14 on: January 7, 2006, 07:24AM »
Hi all,
I've been playing my senator module against various other computers to get a feel for the playing style of the engine, and I noticed something funny - the senator would allow a draw by threefold repetition in positions where it is clearly ahead (own evaluation of position at least 2 pawns better). Yet it would allow the other engine the draw.
The first time it happened was against my Mephisto Chess Challenger. I made sure after that to press the ACL button before any comp vs comp games to reset any funny settings. But yesterday the exact same thing happened when I played it against CSTAl 2 on reduced strength (setting on 15).  The position was in the endgame with both sides having a rook, but the senator being up a knight for a pawn. The position was fairly open (senator was definitely in control of the position - so no chance of an incorrect assessment of a drawn endgame position)
Anyone know whether this is a known bug in the senator module?
Jaco
