June 2, 2020, 08:07AM
News: Visit a member's site: http://www.izarlili.com/ (Kalikolo)
  Mephisto mains adaptors question
   Author  Topic: Mephisto mains adaptors question  (Read 810 times)
drawmeister
How about a nice game of chess ?
Re:Mephisto mains adaptors question
« on: January 29, 2006, 11:35AM »
Hi Robert,
Thanks for your reply.
According to Mephisto catalogues the correct adaptor for say Lyon/ Vancouver is the HGN 5004, then it says 5007 for UK, 5504 for US and 5009 for Aus.
So i am sure i have the correct one as my Lyon was a UK bought computer and came with the 5007.
However i do agree with you that it should only work with 9v so maybe it is just a printing mistake on the adaptor ?. The only way i guess would be to get the output voltage electrically tested.
Ian.
« Reply #1 on: January 23, 2006, 01:20AM »
Hi Ian,
Quote from: drawmeister on January 20, 2006, 08:17AM
According to the instruction manuals the correct mains adaptor for say the Lyon module is HGN 5004A which is the 2 pin European version and has 8V output, however
Hm, should be 9V with 600/680mAh (i know of these two versions), but maybe this makes no difference.
i noticed that my UK equivalent 3 pin adaptor HGN 5007A has only 5v output.
I have never heard of a HGN 5007. Is this maybe a special UK-version? (Google has no results for this, but many for HGN 5004)
But why does it have 5V?
The only Mephisto adaptor with 5 V, that i know, is the HGN 5050 (for Risc I/II and the Saitek Risc 2500)
Both adaptors do work the module ok but if i needed to get a replacement what rating should i get or does it not really make any difference ?.
They both work??? That's astonishing!
Normally all Lang modules need 9 V; only the Risc modules (by Ed Schröder) need 5 V (IIRC they have no voltage regulator, you can damage them with 9V!!)
I don't think, that a normal Lang module should work with 5 V! (mine quit even with 7,5 V!)
Are you using an adaptor module?
drawmeister
« Reply #2 on: January 20, 2006, 08:17AM »
Hi All,
According to the instruction manuals the correct mains adaptor for say the Lyon module is HGN 5004A which is the 2 pin European version and has 8V output, however i noticed that my UK equivalent 3 pin adaptor HGN 5007A has only 5v output.
Hopefully an electronically minded person can answer this.
Thanks
Ian.
