May 26, 2020, 12:32AM
News: Mirror of the old site for Tasc.nl at www.chesscomputers.org
  GK2000 Computer Repair?
   Author  Topic: GK2000 Computer Repair?  (Read 717 times)
Re:GK2000 Computer Repair?
« on: January 23, 2006, 06:28AM »
Mi there Mike,
To add to Robert's comments, because it's all the LEDs, I really think it's probably just one cable/wire that's loose or something like that. Usually they all share at least one common path in the circuit so if one goes out, they all do.
« Reply #1 on: January 23, 2006, 01:39AM »
Hello Mike,
Quote from: Mike Nelson on January 20, 2006, 04:58PM
I've got a Saitek GK2000 computer whose horizontal row of red leds don't function.  The vertical leds do work.  The computer displays the moves in a lcd, so the led coordinates aren't absolutely necessary to play the game.
The million dollar question - would this be something fairly easy to fix if I opened up the unit, or would I run the risk of making an otherwise functioning unit have more problems?
I would open the GK2000 and check all (plastic)cables, if they are correctly connected.
Of course, you should be a little careful!
But it is definitely worth a try!
Mike Nelson
« Reply #2 on: January 20, 2006, 04:58PM »
Hello friends -
If anyone has any experience or suggestions, I'd appreciate hearing them.  Thanks.
