October 16, 2019, 05:38AM
News: Visit a member's site: http://www.pinpoint1.f2s.com/ (Mike Watters)
  Compatibility of 32 bit Munchen Boards
   Author  Topic: Compatibility of 32 bit Munchen Boards  (Read 806 times)
Re:Compatibility of 32 bit Munchen Boards
« on: February 16, 2006, 02:23PM »
On a general note for those looking for info on Mephisto module compatibility you can go to Kurt Kispert's website and the boards that the modules work with are in red for each type of module. Sometimes you have to look at the explanation also.
http://www.schachcomputer.at/mephisto.htm
Gerhard
« Reply #1 on: February 16, 2006, 01:16PM »
the Munich board is per se not a 32bit board. All modules will work in it, even the old 8bit modules like Polgar. Some modules though will come with a "power adaptor module" which should be used then instead of the power connector in the board. The above holds too for the Exclusive and Modular boards. The story is different only with the Bavaria board, which works only with Richard Lang's 16/32 bit programs.
Best wishes, Gerhard
Jaco
« Reply #2 on: February 16, 2006, 10:13AM »
Can someone explain to be the compatibility of a 32 bit Mephisto Munchen board with the range of Mephisto modules (from 68000, 68020 to 68030 and the latest senator and magellan modules). Will this board work with all the modules, or only from the 68020?
Jaco
