January 22, 2020, 12:41AM
News: Visit a member's site: http://www.pinpoint1.f2s.com/ (Mike Watters)
  Mephisto Bavaria - Which modules ?
   Author  Topic: Mephisto Bavaria - Which modules ?  (Read 828 times)
_hard
I love Chess Computers!
Re:Mephisto Bavaria - Which modules ?
« on: March 15, 2005, 01:34AM »
Hi Mike,
Quote from: Mike Watters on March 15, 2005, 12:55AM
Does the Bavaria board really work fully with the MM I and MM IV modules?
this would surprise me very much.
Bernhard
_hard
« Reply #1 on: March 15, 2005, 01:18AM »
Hi Daniel,
Quote from: Daniel on March 14, 2005, 01:46PM
My question is about which modules do or don't work in the Bavaria board .
as Mike explained, the piece recognition makes the Bavaria board unique. Only newer Richard Lang modules (with dotmatrix display, the first Bavaria compatible was a modified Portorose in 1990) like Vancouver 16/32 or Genius 68030 are prepared to support it and will work. No Polgar, RISC, Magellan ...
Bernhard
« Last Edit: March 15, 2005, 03:39AM by _hard » Report to moderator Logged
« Reply #2 on: March 15, 2005, 12:55AM »
Daniel. As Alain says, it is the information in red.
« Reply #3 on: March 14, 2005, 09:46PM »
on http://www.schachcomputer.at, you gan find this compatibility information.
Polgar module is not compatible with the Bavaria (see http://www.schachcomputer.at/mephist2.htm)
« Reply #4 on: March 14, 2005, 03:21PM »
My question is about which modules do or don't work in the Bavaria board . I don't know anything about the Mephisto computers. I would have immagined that all modules should work. After all , that's the point of a modular system. But from what I've read, it looks like some do work for sure and others don't , and yet others may work only some of the time ! Can anyone here tell me which modules will or will not work FOR SURE in a Bavaria ? Will Polgar work ? Also, why do some module sets come as 3 pieces and others only as 2 ? And can the LCD be used with any modules ?
Thanks in advance . And ismenio, keep up the good work .
Daniel
Daniel
I have brought up an earlier thread about Mephisto modules. See the Hegener & Glaser thread.
The thing about the Bavaria board is that it recognises each piece type as it is placed on the board e.g. white pawn, black rook etc. None of the earlier modules provided for this so they will not work with the Bavaria piece recognition. Bernhard would be able to tell you whether they are totally incompatible. It may be just the 16/32 bit modules which work with the Bavaria.
The third module in some sets is a power supply module. I assume that there may have been problems with power supply for the more powerful modules so the adaptor lead plugs into the top of this module rather than into the side of the board. Having said that my Genius 68030 London works fine without the extra module.
Certain modules eg the Polgar, Genius have two lines of information on their displays; others have large digits in a single line e.g. Senator. For instance my MM IV or Senator will not work with a Polgar display and vice versa.
Hope this helps for now.
« Last Edit: March 14, 2005, 03:28PM by Mike Watters » Report to moderator Logged
Daniel
« Reply #5 on: March 14, 2005, 01:46PM »
Hello All,
Firstly , thanks and compliments to ismenio for providing this site and board for our pleasure.
Daniel
