September 25, 2018, 03:03:00 AM
  Elan Chat (Only)
  71 elan steering fixes
   Author  Topic: 71 elan steering fixes  (Read 1120 times)
Hoot619
« on: December 15, 2014, 03:49:49 PM »
Have spreaders but no help. Need more down force
EricR
Lookin like a fool with your pants on the ground!
Re:71 elan steering fixes
« Reply #1 on: December 15, 2014, 04:02:25 PM »
Step 1 loosen track
Step 2 remove front bogies
Step 3 drill a hole about 1 to 1 1/2" higher than where the bogie mounting tab is, your bolt will not be above the running boards.
Step 4 reinstall bogies and re adjust track. Enjoy actually turning when you move the bars
I didn't take pics but I did this to my 71 and it's great. I can actually turn the thing on GRASS now. Why didn't I do it years back? I did this to my 69 Oly and it turns too.
Yellow Fevah!
moxymech1
« Reply #2 on: December 15, 2014, 04:07:57 PM »
Ditch the widers! They will will bend the spindles.
Best way for ski pressure is wood blocks like so
Moxy
« Reply #3 on: December 15, 2014, 04:20:09 PM »
Quote from: EricR on December 15, 2014, 04:02:25 PM
Looks like a typo here....your bolt will "now" be above the running boards.
This is a good technique, I've used it and I like it.
EricR
« Reply #4 on: December 15, 2014, 04:23:33 PM »
'Twas the typo before Christmas.....
Yellow Fevah!
EricR
« Reply #5 on: December 15, 2014, 04:24:51 PM »
Moxy
What's in the tub?
Yellow Fevah!
« Reply #6 on: December 15, 2014, 05:45:03 PM »
My guess is sap gathering gear
Hoot619
« Reply #7 on: December 15, 2014, 08:27:53 PM »
Thanks all, will try the wood blocks first I think.  If I don't like them will  do the raising of track in front this spring.  Hoot
« Reply #8 on: December 16, 2014, 02:48:16 AM »
Something else to consider is 71 didnt have much in the way of leaf springs on the skis.  I am planning on putting 74 elan leaf's (3 per side instead of 2) into my 71...  hopefully that adds some pressure.  The originals were pretty weak, on mine at least.
« Reply #9 on: December 16, 2014, 08:48:00 AM »
What's in the tub?
ADULT BEVERAGES
premixer
« Reply #10 on: December 16, 2014, 10:49:50 AM »
I am currently replacing all the bogies, I will definately be moving my forward set up into the tunnel.
1971 399 Oly
1972 Kitty Cat
1973 Elan SS
1972 Evinrude Trailblazer 437 Opposing
One of them Sno Runners
1971 Triumph Bonneville
1996 440 Touring
2005 Arctic Cat Z570 (daily rider)
moxymech1
« Reply #11 on: December 16, 2014, 03:15:10 PM »
In the tub is my rock core logging equipment and my lunch
Moxy
Poidy
What's under your hood........
« Reply #12 on: December 17, 2014, 11:28:43 AM »
Funny how some years elans act different on steering then others, we have tried everything, I just go with the flow now lol body english when trying to corner, think I would know how to doo this since 71?
http://poidy.pages.qpg.com/index.html
Banoe
« Reply #13 on: December 17, 2014, 06:41:07 PM »
My 71' handles better than my 72'.  It has spreaders on the skis but they are swept back instead of forward that gives the sled a shorter ski base.  I tried the spreaders on the other way but the skis kept flipping because the 71' Elan doesn't have a travel stop on the spindle.
EricR
« Reply #14 on: December 18, 2014, 07:14:02 AM »
Moxy, what is rock core logging?
Yellow Fevah!
moxymech1
« Reply #15 on: December 20, 2014, 10:56:47 AM »
Eric, rock core logging is measuring diamond drill samples for rock quality design.  It is essentially what engineers use for determining foundation design for bridge abutments.  It's part of what I do for "work"
Moxy
Hoot619
« Reply #16 on: February 3, 2017, 12:57:39 PM »
Finally put the wood blocks on skis, I haven't run it for a few years. I'm getting a little old so will have it for next deer season. New battery the coming week. Will try to get electric start to work. 4 wheeler let me down deer season snapped an axle at end of season. The long walk to blind..no good
Will try to stay at it!Can't keep putting things off-I'm 74 .
hotdoo
The older,the odder the better
« Reply #17 on: December 19, 2017, 05:28:31 PM »
I did this and it worked great. I took front set of bogies and cut the whole thing down in length by 3/4",retapped the holes,took a plate-1/2 by 3 drilled one pass though hole and another with a taper on outside. Now you can drill the pass though hole  1" from end on 3" plate ,then drill the tapered hole 1" from the other end. Put a bolt with tapered head into the end of aluminum rod on both ends,now rotate the whole bogie gang higher into tunnel and bolt pass though hole on plate into existing tab. Now your gang is higher in tunnel so you have less track weight and more down pressure on skis.
71ELAN
ELAN - "Inspired by passion and enthusiasm"
« Reply #18 on: February 13, 2018, 01:21:18 PM »
I had the same problem with my 1991 elan, no ski pressure. I added carbides, 4" to the skis and now it turns.  I could see possibly moving the front bogies up a little though if needed.
1971 Elan 250E - home made rear rack
1973 Elan 250T - Mint
1973 Elan 250T - Parts
1974 Elan 250T - VG+
1974 Elan 250T - All Black VG+
1974 Elan SS - 340cc every nut an bolt turned, rear rack some customizing
1991 Elan --  my first sled, 1 owner
1994 Elan - 335cc racer 34mm mikuni, pipe
