#oldski-doosleds #vintageski-doo #vintageskidoo © 2018
March 25, 2019, 09:47:20 AM
  Tank Brigade
  Here's my RD-8
Pages: 1 [2] Reply Notify of replies Send the topic Print
   Author  Topic: Here's my RD-8  (Read 1764 times)
hotdoo
The older,the odder the better
Re:Here's my RD-8
« Reply #20 on: July 20, 2017, 06:45:31 PM »
Okay moving on,anyone know which way the seat is hinged,this one had a old hinge in front,is that right?thanks hotdoo
Re:Here's my RD-8
« Reply #21 on: July 22, 2017, 08:09:31 AM »
My 68/69 was hinged along the rh side when I got it.  Seems right to me, though mine wouldn't be able to tilt forward because the engine/carb would be in the way.
hotdoo
Re:Here's my RD-8
« Reply #22 on: October 18, 2017, 04:03:04 PM »
'63's were made opening to front.hotdoo
hotdoo
Re:Here's my RD-8
« Reply #23 on: February 8, 2018, 04:10:17 PM »
Ok, yesterday the '63 RD-8 drove out of barn,not to far though, it seems the chain is jumping the top sprocket. I have the chain tensior bolt screwed all the way and it still loose. Chain tensioner does push the chain into the center of case does it not? Thanks for any thoughts , hotdoo
Longnecker
Re:Here's my RD-8
« Reply #24 on: February 8, 2018, 06:59:58 PM »
Are you sure the chain is jumping and not the front axel sprockets jumping the track windows?  Loose track?
Re:Here's my RD-8
« Reply #25 on: February 8, 2018, 08:16:01 PM »
I don't have a 63 to compare to, but if it's anything like the 68 style the top sprocket is held within an oblong aluminum block.  The bolt just holds it in place.  To tighten the chain you have to rotate the aluminum block after loosening that bolt.  This is assuming there is a slot for the bolt to move back and forth within.  I could be wrong but that's what I envision to tighten the chain.
Re:Here's my RD-8
« Reply #26 on: February 13, 2018, 09:51:35 AM »
As you likely already know the earlier alpines were definitely different in this regard.  I looked up a 66 secondary which is likely closer than what I talked about.  As far as the tensioning bolt its hard to say from the picture if that little idler sprocket makes the chain tighter or looser from screwing it in.  But if you hadnt seen this before thought it might help you understand whats inside.
hotdoo
Re:Here's my RD-8
« Reply #27 on: March 8, 2018, 11:45:46 AM »
Well, that case doesn't have a concentric to it, all it has is the idler to push into chain to take up lack, I put a little longer bolt in it but I still need a longer all -threaded bolt. hotdoo
Re:Here's my RD-8
« Reply #28 on: March 8, 2018, 03:10:28 PM »
Maybe the piece that has the female threads is stripped?
hotdoo
Re:Here's my RD-8
« Reply #29 on: March 27, 2018, 04:41:31 PM »
No It's not stripped, I even took the adjuster nut,part number 15 off the bolt so I could get more length. I thought I matched up old chain to new chain perfectly but needless to say I f--up somewhere,hotdoo
