June 17, 2019, 02:32:51 PM
  Tip Of The Day
  Clean gas tanks
   Author  Topic: Clean gas tanks  (Read 515 times)
69nordic
Clean gas tanks
« on: November 29, 2017, 05:57:32 PM »
    The best way to clean a plastic gas tank.
Dump in straight methyll ethyl ketone slosh it around for a few minutes all goop varnish gone.
I have no idea what harm it could do to the human body so use it at your own risk research how to use it etc etc
I pour it back in the can and use it over and over this really works good for me.
Kash
cdem72
One shrunk because I soaked it in hot water!
Re:Clean gas tanks
« Reply #1 on: December 19, 2017, 08:58:21 AM »
FYI: from safety data sheet: methyl ethyl ketone
H225 - Highly flammable liquid and vapor
H319 - Causes serious eye irritation
H336 - May cause drowsiness or dizziness
P210 - Keep away from heat/sparks/open flames/hot surfaces. - No smoking
P233 - Keep container tightly closed
(Generally not toxic)
« Last Edit: December 19, 2017, 08:58:48 AM by cdem72 » Report to moderator Logged
'62 tincab; '69 399 T'NT; '70 292, 340 bliz, 340 T'NT; '71 246, 291 bliz, 440, 640, 775 T'NT; '72 293, 340, 440 bliz; '73 345 bliz, '74 440 T'NT, '75 245 rv
