April 24, 2019, 05:47:37 AM
  Tip Of The Day
  Specialty tools made at home
   Author  Topic: Specialty tools made at home  (Read 623 times)
« on: January 21, 2017, 08:59:40 AM »
39 degrees, rainy, foggy……seems like a good day to get some project ideas.    So, what tools have you fabricated at home?  Here’s a pic of two pullers and a secondary spring attachment fixture.  The pullers required welder and a lathe, but the spring gauge just cardboard to make a template, a vice to  hold the sheet metal plate, and a hammer to crease the bends.  The screw (10/24) keeps it from sliding under tension.    Use that with a walleye master scale to dial in spring preload.  Works on 70-00 sleds.
« Last Edit: January 21, 2017, 09:04:07 AM by Green and Gold » Report to moderator Logged
