April 18, 2019, 06:23:27 AM
  Need help: Splitting crank shaft to get rod bearings out.
   Author  Topic: Need help: Splitting crank shaft to get rod bearings out.  (Read 1964 times)
steele86
« on: June 11, 2011, 07:06:34 PM »
Hello, does anyone know how to split the crank shaft on a 93 sea doo with a 580 Rotax engine? I need to replace the rod bearings. Any help is greatly appreciated!
snocrusher
Re:Need help: Splitting crank shaft to get rod bearings out.
« Reply #1 on: June 18, 2011, 10:41:53 AM »
I am going out on a limb here and surmising why you haven't a response yet after a week and 34 reads, is because the subject is way too new and worse it is a personal watercraft, even though it is a SkiDoo.
Crankshaft repair is a very specialized procedure and should not be tackled by a novice if you expect good results.
You are best advised to find a a shop specializing in 2 cycle crank repair like http://www.cvtech-aab.com/contenu/index_ang.cfm
Good luck
Whiskey Ditch Relic Riders_____Ride'em...Don't hide'em
Website wdrr.ca
racer669
« Reply #2 on: July 29, 2011, 12:52:50 PM »
Yes there are specialty tools and fixtures required....and a big press helps too.
I am not saying that a DIY guy can't do it, because some people are very handy, especially when faced with a challenge.
HOWEVER, it is likely best to enlist a shop that does this.
My shop does this , and I even have a 587 Sea-doo crank in stock ready to ship.
www.bracebridgemachine.com
Cheers, Roy.
