June 19, 2019, 02:43:34 PM
  399 rotax problem
   Author  Topic: 399 rotax problem  (Read 367 times)
tuned_pipe
399 rotax problem
« on: January 12, 2013, 05:36:33 AM »
hi all ..i have a 1970 tnt rotax 399 thats doing werd things .. i have rebuilt the carb ..  new plugs. new plugs wires .. i have gas going to the carb .. sparks on both plugs .. good compr.  but it will run only on 1 cylinder .it starts .idles good but will run only on the cutch side . i pull the mag side plug out and it as great spark .. anybody can figure this one out .we are going to arizona  for a few weeks  and hoping i can solve that issue  before i leave .. thanks PAUL
« Last Edit: January 12, 2013, 05:40:44 AM by tuned_pipe » Report to moderator Logged
Re:399 rotax problem
« Reply #1 on: January 12, 2013, 08:49:27 AM »
I HAD THE SAME THING HAPPEN TO ME ON A 640 71 TNT. THE GUY PUT TO MAG PISTONS IN THE MOTOR. SO THE PTO WOULD NOT RUN. MAYBE YA GOT ONE WITH TWO PTO PISTONS IN IT. SO THE MAG WILL NOT RUN??????
OR YA GOT A BAD GROUND WIRE FOR THE MAG COIL AND SOMETIMES IT WORKS BECAUSE YA MOVING THE WIRES. HAD THAT HAPPEN TO ME ON A 292. SPAARK ON THE BENCH AND PUT IT IN THE SLED AND NO SPARK.  YETI
tuned_pipe
« Reply #2 on: January 12, 2013, 02:32:52 PM »
hi joe .. could be a wire ..  but i never lost spark .. it still runs on the clutch side .. i took the magneto plug out and grounded  and it runs on the clutch side with a lot of sparks on the magneto plug ..  but when i change  nothing  wont even make a poof ..
SLEDRZ
« Reply #3 on: January 12, 2013, 03:06:21 PM »
Mag side crank seal gone or like Joe says piston in wrong or wrong piston? My 775 had the pistons in reversed order, mag in pto and pto in mag. It would run but spit the fuel back through both carbs, enough to soak the taillight.
1965 OLYMPIQUE
1969 12/3 OLYMPIQUE
1969 Ski-doo Tube Trailer scrapped
1970 12/3 OLYMPIQUE with Wunder Wheels kit
1970 Blizzard 640 current restoration project
1971 OLYMPIQUE 335 parted out and scrapped
1972 T'NT 775
1972 T'NT 640 Sold
1972 T'NT 400 Sold
1972 T'NT 340 S
tuned_pipe
« Reply #4 on: January 13, 2013, 04:53:59 AM »
thanks for the input .. could be a seal .. as the motor looks like it never been open .everything is at it came out of the factory .. if not a seal .. i dont know what it could be .. thanks
Banoe
« Reply #5 on: January 13, 2013, 06:13:18 AM »
Did you try swapping coils to see if the problem changes sides?
VSDPS
Hello boys...I'm baaaack
« Reply #6 on: January 13, 2013, 06:46:58 AM »
Paul, what do you have for Comp? I know you mentioned it was good, but what does the gauge read? Could also be a timing issue.
7doos
Ski Doo #1 always was, Always will be!
« Reply #7 on: January 13, 2013, 07:31:10 AM »
I had the same issue with my 440 tnt years ago. Every time I checked it had spark. It would run a little while and then drop out. It ened up being the coil on that side. Once I replaced that coil it ran fine.
66 oly, 68 oly, 70 399e nordic, 70 292TNT, 71 Elan, 72 440TNT, 76 elan deluxe, 2)75 245RV 's, 76 250& 340 RVs, 77 RV, 78 RV, 78 Everest 340, 81 3500 Citation, 85 formula SP,  94 formula Z, 05 REV 600SDI
