June 24, 2019, 02:39:30 AM
  carb spitting gas
   Author  Topic: carb spitting gas  (Read 478 times)
1 lunger doo
sometimes it's okay to be yellow
carb spitting gas
« on: January 10, 2013, 09:25:49 PM »
what would be the reason(s) for gas shooting out the carb?
Rockalicious
Only dead fish go with the flow
Re:carb spitting gas
« Reply #1 on: January 12, 2013, 11:33:07 AM »
My tilly HR carb does that a little bit. I notice it more when the breather box is off of course. I think its normal.
'69 Ski Boose MKII
'70 olympique 12/3
'74 wife
'75 elan 300ss (sold)
'76 elan 250e
'86 Yamaha Bravo 250
Yukon Jack
She ain't pretty...
« Reply #2 on: January 19, 2013, 03:10:18 PM »
It gets worse if the check valve in the high speed jet is stuck open. If it's bad enough, the motor will flood.
Rockalicious
« Reply #3 on: January 21, 2013, 05:17:55 PM »
Quote from: Yukon Jack on January 19, 2013, 03:10:18 PM
You mean flood your crotch?
'69 Ski Boose MKII
'70 olympique 12/3
'74 wife
'76 elan 250e
aDOOrondack
« Reply #4 on: January 21, 2013, 05:47:40 PM »
Similar problem:
Mine ran fine on the stand at lower RPM, but when run 15-20sec at 1/2 to 3/4 throttle and then backed off the carb immediately spit gas halfway back on the seat, hear gas being sucked back into the tank, and stalls.
Suspect the tank vent may be blocked, but haven't checked yet.
70 Oly 335E, 81 Citation SS
charlie73
« Reply #5 on: January 21, 2013, 06:16:33 PM »
Pull the welch plugs out of your carb and check the surface of the seat and ball in your check valve. They often collect corrosion and do not seat fully.
« Last Edit: January 22, 2013, 06:20:24 AM by charlie73 » Report to moderator Logged
