March 20, 2019, 09:26:12 PM
  blizzard wizzards Corner
  245 primer location
   Author  Topic: 245 primer location  (Read 270 times)
hotdoo
The older,the odder the better
245 primer location
« on: June 10, 2018, 04:56:39 PM »
Ok, shows a spot on the dash for primer,but it also has the spot next to recoil handle,where's it go? Also what were the original carbs? I can't find the barbs for the primer hose on my carbs at all. Thanks hotdoo
Blizzard GR
Debut of the new 1970 Blizzard in fall of 1969
Re:245 primer location
« Reply #1 on: June 18, 2018, 01:43:39 PM »
Hotdoo, the carbs were 34mm and had both primers and choke levers. The primer pull was in dash. That piece the recoil goes through was used on other doo sleds that had the primer there. If you need the mikuni VM number, I may have it for the 245.
Thanks.
John
« Last Edit: June 18, 2018, 01:57:16 PM by Blizzard GR » Report to moderator Logged
My stuff:
# Phil Mickelson's Open Class alky Blizzard he ran from 1970-'72.
# Larry Rugland's factory 1976 Ski-Doo 440 liquid Sno-pro, starting resto
# 1999 Mini-Z for when the grandkids visit
# 1975 Can-am 125 T'nt
hotdoo
« Reply #2 on: June 20, 2018, 06:05:03 PM »
Thanks Blizzard,after taking carbs off I found the fitting for primer with tiny screws put in it,how I missed them while I cleaned them I don't know,hid under choke lever maybe. So I think it has the right carbs on. Did find that NOS LLP cables are junk,broke the one on sled taking carbs off,went to dealer he had 8 LLP cables but when we tested them almost all of them broke the ends off the parts that locks in slide barrel. hotdoo
Blizzard GR
« Reply #3 on: June 21, 2018, 01:58:02 PM »
Excellent on finding the primer outlets!
As for mikuni  throttle cables, I find the ones Wahl Bros sell to be very nice. Check them out on line if you get a chance.
Good luck, Hotdoo!
John
My stuff:
