November 20, 2019, 02:14:58 PM
  One-Lunger Help Desk (Only)
  carb nut wrench
   Author  Topic: carb nut wrench  (Read 626 times)
krusty
Sr. Member
carb nut wrench
« on: March 24, 2017, 03:33:06 PM »
Hi folks,
Just wondering what people use for tightening the two nuts to keep the carb attached to the engine? The left hand one is easy to access, but the right is difficult. Certainly there has to be an easy way to do this. I heated up a wrench and bent it, but it is still a bit of a challenge.
Krusty.
EricR
Lookin like a fool with your pants on the ground!
Re:carb nut wrench
« Reply #1 on: March 24, 2017, 04:14:01 PM »
I have used a thin, long punch to loosen and tighten the nut.
Yellow Fevah!
olympic
Re:carb nut wrench
« Reply #2 on: March 24, 2017, 04:49:29 PM »
I have the open end wrench that came with the tool set in my dads 71 elan 250 that I have now. It is bent at a 90 on one end just so you can get on the nut. I have in the past when that right side nut is tough to get off I have taken a little cresent wrench put on to give some leverage. I know what you mean by its tight.
69 Olympic370,71  Elan250,1980 Blizzard9500plus,2000 MXZ440F,2002 MXZ600
krusty
Sr. Member
Re:carb nut wrench
« Reply #3 on: March 24, 2017, 05:13:02 PM »
any chance you could post a couple pics of that open end wrench? I should be able to make something up crude with some 12 or 10 GA sheet and my die grinder.
olympic
Re:carb nut wrench
« Reply #4 on: March 24, 2017, 06:18:40 PM »
[/URL]
[/URL]
« Last Edit: March 25, 2017, 04:07:41 AM by olympic » Report to moderator Logged
EricR
Re:carb nut wrench
« Reply #5 on: March 25, 2017, 07:10:09 AM »
I have one of those, works pretty good and easy to duplicate- came from the original took kits.
Yellow Fevah!
