October 13, 2019, 04:36:09 PM
  Elan swap
   Author  Topic: Elan swap  (Read 303 times)
krusty
Elan swap
« on: December 8, 2018, 04:42:32 PM »
Gang,
Picked up an Elan today locally. A bit more rust than I wanted but the rest is in OK shape. Has a running 250 in it, but I have a 335e I want to swap in instead. Any considerations or pop in and go?
Things are freezing up nicely in the swamp so far for mid Dec!
Krusty,
dando127
Re:Elan swap
« Reply #1 on: December 8, 2018, 05:14:16 PM »
I did a 318 into a 77 Elan deluxe with no issues.  A little bit tight to change the spark plug but still do-able.  If your Elan has a single chaincase you may want to try to find a double one.  Good luck.
« Last Edit: December 8, 2018, 05:43:05 PM by dando127 » Report to moderator Logged
Poidy
What's under your hood........
Re:Elan swap
« Reply #2 on: January 15, 2019, 06:07:41 AM »
yes doble chain for sure, 335 292 340 break those single chains easy, as for plug, ya I cut  a bit out of the metal makes life easier, other then that just a drop in swap?
http://poidy.pages.qpg.com/index.html
